Подбор цепей противоскольжения RS
Сообщение Ekaterina » 13 дек 2013, 09:46
Цепи противоскольжения RS 40 9 мм
135 r15, 155/80 r13, 175/60 r14, 195/45 r14, 155 r13, 165/60 r14,175/65 r13, 195/55 r13, 135/80 r15, 165/65 r14, 185/50 r14, 155/65 r15, 165/70 r13, 185/60 r13
Цепи противоскольжения RS 50 9 мм
145 r15, 165/70 r14, 185/50 r15, 195/45 r15, 165 r13, 165/80 r13, 185/55 r14, 195/55 r14, 145/80 r15, 175/55 r15, 185/60 r14, 155/70 r15, 175/65 r14, 185/70 r13, 165/65 r15, 175/70 r13,195/40 r16
Цепи противоскольжения RS 60 9 мм
165 r14, 175/65 r15, 185/65 r14, 175 r13, 175/70 r14, 195/45 r16, 165/75 r14, 175/80 r13, 195/50 r15, 165/80 r14, 185/50 r16, 195/60 r14, 175/60 r15, 185/55 r15, 205/40 r16
Цепи противоскольжения RS 70 9 мм
165 r15, 175/75 r14, 195/45 r17, 205/45 r16, 225/40 r16, 175 r14, 175/80 r14, 195/50 r16, 205/50 r15, 165/80 r15, 185/55 r16, 195/55 r15, 205/55 r15, 175/55 r17, 185/60 r15, 195/65 r14, 205/60 r14, 175/70 r15, 185/70 r14, 205/40 r17, 215/40 r16
Цепи противоскольжения RS 80 9 мм
185/65 r15, 195/70 r14, 215/45 r16, 185/70 r15, 205/45 r17, 215/50 r15, 195/55 r16, 205/50 r16, 225/50 r15, 195/60 r15, 215/35 r18, 195/65 r15, 215/40 r17
Цепи противоскольжения RS 90 9 мм
185 r14, 195/80 r14, 205/70 r14, 225/35 r18, 195 r14, 205/50 r17, 215/40 r18, 225/45 r16, 185/80 r14, 205/55 r16, 215/45 r17, 225/50 r16, 195/60 r16, 205/60 r15, 215/50 r16, 245/35 r17, 195/70 r15, 205/65 r15, 215/60 r15
Цепи противоскольжения RS 100 9 мм
195 r15 , 205/60 r16, 215/50 r17, 225/35 r19, 225/60 r15, 245/45 r16, 205 r14, 205/65 r16, 215/55 r16, 225/40 r18, 235/40 r17, 195/65 r16, 205/70 r15, 215/60 r16, 225/45 r17, 235/45 r17, 195/80 r15, 205/80 r14, 215/65 r15, 225/50 r17, 235/50 r16, 205/55 r17, 215/45 r18, 215/70 r14, 225/55 r15, 245/40 r17
Цепи противоскольжения RS 110 9 мм
215/55 r17, 225/55 r16, 255/35 r18, 215/60 r17, 225/60 r16, 255/40 r17, 215/70 r15, 235/35 r19, 225/40 r19, 235/40 r18, 225/45 r18, 245/45 r17
Цепи противоскольжения RS 120 9 мм
215/55 r18, 215/65 r16, 225/55 r17, 225/60 r17, 225/65 r16, 235/45 r18, 235/50 r17, 235/50 r18, 235/60 r16, 235/70 r15, 245/35 r19, 245/40 r18, 245/40 r19, 245/45 r18, 245/55 r16, 255/35 r19, 255/40 r18, 255/45 r17, 265/40 r17
Цепи противоскольжения RS 380 16 мм
195 r15, 205 r14, 185/75 r16, 195/80 r15, 205/65 r16, 205/70 r15, 205/75 r14, 205/75 r15, 205/80 r14, 215/60 r16, 215/65 r15, 215/70 r15, 215/75 r14, 225/60 r15, 235/60 r15, 245/40 r17
Цепи противоскольжения RS 390 16 мм
6.00 R16, 6.50 R16, 195 R16, 215 R14, 195/75 R16, 195/80 R16, 205/80 R15, 215/60 R17, 215/65 R16, 215/70 R16, 215/75 R15, 215/80 R14, 225/55 R17, 225/60 R16, 225/70 R15, 235/60 R16
Цепи противоскольжения RS 400 16 мм
7.00 R16, 205 R16, 215 R15, 205/65 R17.5, 205/75 R16, 205/80 R16, 215/55 R18, 215/75 R16, 215/80 R15, 225/55 R18, 225/60 R17, 225/65 R16, 225/70 R16, 225/75 R15, 235/50 R18, 235/55 R17, 235/65 R16, 235/70 R15, 255/45 R18, 255/60 R15
Цепи противоскольжения RS 410 16 мм
30 R9.5, R15, 225/60 R18, 225/65 R17, 225/75 R16, 235/55 R18, 235/60 R17, 235/70 R16, 235/75 R15, 245/40 R20, 245/45 R19, 245/50 R18, 245/55 R17, 255/50 R17, 255/65 R15, 255/70 R15, 275/55 R16, 275/60 R15
Цепи противоскольжения RS 450 16 мм
7.5 R16, 8 R17.5, 8.5 R17.5, 215 R16, 235 R16, 205/75 R17.5, 215/75 R17.5, 215/80 R16, 215/85 R16, 225/65 R18, 225/70 R17, 235/50 R19, 235/55 R19, 235/60 R18, 235/65 R17, 235/70 R17, 235/75 R16, 235/80 R16, 245/60 R18, 245/65 R17, 245/70 R16, 245/75 R16, 255/40 R20, 255/45 R19, 255/55 R18, 255/65 R16, 255/70 R16, 255/75 R15, 265/35 R21, 265/70 R15, 275/40 R19, 275/45 R18, 285/40 R18
Цепи противоскольжения RS 460 16 мм
7.50 R18, 10.00 R15, 31 R10.5, R15, 225/75 R17.5, 235/55 R20, 235/65 R18, 235/85 R16, 245/50 R20, 245/70 R17, 255/50 R19, 255/50 R20, 255/55 R19, 255/60 R17, 255/60 R18, 255/65 R17, 255/75 R16, 265/40 R21, 265/50 R19, 265/65 R17, 265/70 R16, 265/75 R15, 275/40 R20, 275/45 R19, 275/45 R20, 275/50 R19, 275/55 R17, 285/35 R21, 285/45 R19, 285/50 R18, 295/35 R20
